So my wife's Alero (2003 w/ 2.2L Ecotec) has had some starting issues for the last month almost. I haven't had much time to work on it (it broke down a day before we started moving to a new house), but I have changed out the ignition module, fuel filter and fuel pump. After the new fuel pump, I was having issues with it not starting at all. I thought I finally got that figured out last night, and was able to drive it around for a little while and all seemed fine. She went to go take it to work today, and it wouldn't start again. So I went out and looked at it, and I can't hear the pump priming at all when I first turn the key on. The was happening a couple times last night, but went away. I figured last night it might have had air in the lines, causing it to not prime. But since I got it started and running last night, I just don't see more air in the system causing the issues. Is there anything else that could cause the fuel pump to not prime?? I'm starting to think it might be a PCM issue, but that's not something I want to buy unless I know for sure...
1 more thing to note, just in case... When I initially turn the key to RUN (not START), the CEL is not on, but will turn on after ~10 sec. I wouldn't think if a code was set, it would be on right away. When it was running last night, the CEL light was off.
