I know how to weld.
What I need to know is if it is ok to tack up an exhaust pipe while still in the engine bay? Will it damage the PCM? The electrical surge of sorts? Other sensors at risk?
I will have the ground wire on the same pipe welded.
Using a Mig welder no gas (flux core). I have to join the wastegate to the down pipe. All the pipe is welded up except for the very last seam. And this seem needs to be perfect. To hard to mark and weld off the vehicle, it won't bolt up right. Even 2mm off can cause a problem, I know, I had to cut the last weld out.
I'm going to cover the engine and set up to only expose a small section where I'm welding.
My only real concern is surging electricity into the engine bay. I know it will ground into the ground contact wire, but not sure if it will cause any electrical spikes or EM fields that could harm sensors/pcm, ect.
....help please
....help please
