Ok, for all you experienced welders out there, I have a couple questions...
I'm using a stick welder, and I know most people around here use MIGs, so I'm not sure if the issues I'm having are problems with MIG as well. Anyway, I'm working on a project where I have to fill some holes solid (holes are usually 1/4" or 3/8"). The metal is probably 16ga. My problem is burn-thru. Once I get the arc struck, I end up enlarging the hole even before I start to fill it. Once I do get it filled, I go to grind it down and find some voids/holes in the weld. So then I weld those up. Grind down again and find new holes/voids. I thought that I might have the current up too high, so I turned it down and I'm still having the same problems.
Anyone have any suggestions to what I can do?
