i am considering putting a hypertech peformance chip in my 2.8 wanted 2 hear the pros and cons
hypertech peformance chip and thermostat
Go with this instead: http://wot-tech.com/shop/all/87-91-a...p/prod_20.html-Brad-
Originally posted by bszopi View PostGo with this instead: http://wot-tech.com/shop/all/87-91-a...p/prod_20.html
Both my 91 and 92 have custom tuned chips by Ben, the owner of WOT. Ben is a good guy and does good work.Originally posted by king4u253 View Posthave u used that chip before-60v6's 2nd Jon M.
correct, when you pull the two screws out, the cover will come off and you'll see a blue plastic object, should have a silver sticker on it with a 4 letter code. if it's not on the outside of the MEMCAL(blue plastic object), then remove the MEMCAL from the ECM, then look through the little sight-hole in the top, you should be able to see the sticker from there. if not, then CAREFULLY remove the blue cover via the little tabs on the side(they're pretty brittle).
And use the LETTERS, not the numbers when you order the chip.-60v6's 2nd Jon M.
so i finally got some free time 2 mess with the car.....first off i sounded way easier then it was but fom diffivulty 1 to 10 its about a 5 and i say that just becuase the bolts on the right side arnt visible i had 2 pull my ecm out to get to the two bolts if anyone else is planing on doing this be smart and do like i did and not put the bolts back on the right side since im gonna take it back out when my perforamce chip arrives
