Link to article
I bet a Megasquirt PCM could be built to do this. It's basically a diesel engine but incorporates gasoline.
According to the designers, it can yield a 20% greater fuel efficiency. For others, it could mean more power or offer unique properties for boost? It does have temps 40% lower...in the article.
The concept is using the diesel fuel like a liquid spark plug allowing a more efficient gasoline burn.
So install an extra set of fuel injectors, line, pump/tank, and drop in megasquirt built to accomodate the additional injectors. Or even piggy back a controller for the additional injectors.
It seems like a project full of challenges but I can't see it being much harder then some things I see out there.
Two remarkable things happen in the gasoline-diesel mix, Reitz says. First, the engine operates at much lower combustion temperatures because of the improved control — as much as 40 percent lower than conventional engines — which leads to far less energy loss from the engine through heat transfer. Second, the customized fuel preparation controls the chemistry for optimal combustion. That translates into less unburned fuel energy lost in the exhaust, and also fewer pollutant emissions being produced by the combustion process. In addition, the system can use relatively inexpensive low-pressure fuel injection (commonly used in gasoline engines), instead of the high-pressure injection required by conventional diesel engines.
