In OT because this is in regards to my 2006 Dodge Dakota ST (3.7L/4sp auto/4x4).
I'm the second owner and there are 80k miles on the truck. I don't know the prior service history but what lead me to buy this truck (I looked for 6 months) was that it was by far the cleanest, most rust free one I came across.
The truck makes a metallic clink/clunk sound over small bumps. I mean literally cracks in the road will cause this sound. It isn't too loud and I can't really hear it unless the windows are down. It will make the same noise at 4mph as it will make at 40, and again only small stuff like a bigger crack in the road, a manhole cover, etc. It sounds like it comes from the front drivers side suspension. If I drive over a big bump (like a speed bump) it does NOT make the noise.
Dakotas kind of got a bad rep for wearing out ball joints, so I checked that first. I raised the front wheels off the ground and supported the truck with jack stands under the front axle. I then performed the "wiggle test" on the wheels. Meaning, I pulled, pushed and pryed on them in all directions in an attempt to identify slop in a bad ball joint. I found none. Is there another or better method? I think I can possible use a pry bar to try to separate the hub from the control arm to see if I can get play that way.
Second thing I checked was the front sway bar. I really hoped it was this, and it would make sense, if it shifted to one side and was making contact over the small bumps but when the suspension compressed over big bumps it cleared whatever it was hitting. No such lke, it looks perfectly centered and clear of all obstacles. End links look like good as do the bushings.
So, what else can I check? Is there a better way to check ball joints? The clinking sound drives me nuts since its nearly constant as our roads are not perfect. The truck is about to take over daily driver duties for the winter and I was hoping to resolve this before the snow came.
Help me out!
thanks, John
Help me out!
thanks, John
