So i have this 1995 GM 1500, 4x4 5.7, 5 spd standard, with the aluminum drive shaft with plastic coating. not to long ago i replaced all the rear end seals due to leaks, the noise was there prior, but everything in the rear end was nice and tight and the original diff fluid was rather clean, This noise was there prior to the work, so just trying to make the problem make sence.
So, in any gear, except 1st, under load, with rpms between 1200-1500 (seems to cut out there 90% of the time) there is this horrible rattle coming form the rear of the truck(sounds like). You would think its a bad diff, because the noise is very simmilar to a bad coast noise on a front diff. this noise has progressively gotten louder, and i do not have the option of running it up on a hoiste. I'm thinking its the clutch or maybe just maybe the trans mount.
Also, anther weird issue is when trans is warm (30 min city driving usually) shifting into all gears is a bitch! checked the fluid, it was suggested to switch to a gear oil, but it calls for that GM syncromesh crap.
Feel free to share anyones similar experiances....
