Well, not a 60v6 but thats ok since we are in OT.
This is on my 2006 Dodge Dakota ST 3.7/4x4 4sp Auto
Truck has 80k on it
I'm leaving little stains in the driveway everywhere I park and from the best I can tell it is coming from the pinion seal on the rear diff. To replace the seal, I imagine I'll have to unbolt the u-joint, drop the driveshaft and remove the pinion nut.
My concern comes on reassembly. I believe there must be a spec'd amount of preload on the pinion bearing, meaning that the pinion nut has to be tightened to spec. I'm not sure if it uses a crush sleeve or not, and if it did would it be necessary to replace it? I've read that others (apparently this is a common problem on the Dakota) have used an impact gun to remove and install the pinion nut with little regard for preload or a torque spec - they report no problems after but an improper amount of preload may not show ill effects immediately either. Others still, use hand tools to remove the pinion nut and count out how many turns it took and ensure that on reassembly it goes the same number of turns.
Anyone have any experience on this? I'd hate to have to farm this out to a 'pro' and I flat out couldn't even afford to do that right now. Since the truck is my winter driver and I can't afford significant downtime I may just check the oil level and top it off for now.
Truck has 80k on it
