I noticed how water can be atomized around 22 kHz sound and effectively with only 20 watts per piezo transducer.
With one speaker per runner, each at 14v pushing a max of only 9 amps for all 6 piezo transducers, the load is low. Making it possible to recover more power from a better atomized fuel vapor.
It is a well known process for water atomization and is used for mineral extractions from what I can gather.
Fuel would obviously require a unique frequency to atomize, or maybe it is close to water's frequency.
I thought about directing the sonic waves towards the opposite side of the intake runner where there is a parabolic dish shape to reflect the waveform almost fully intact. Kind of like a sonic laser where sound waves are amplified by preventing the energy in the sound wave to dissipate outwards. The fuel saturated intake air would pass through the region and, hopefully, atomize better combustion. It would also produce a slightly cooler intake temp as atomizing draws heat like evaporation by encouraging rapid evap.
Meh, an interesting idea I thought I'd share and see what you guys think.
Because the soundwave is reflected back at the speaker, recycling the impulse ,amps needed to drive enough energy may be reduced greatly. Or only use the system during idle and lean cruise to maximize fuel economy.....we all love fuel economy with zero impact on performance.
