what is considered a 60 degree V6? I have been curious about that every since i joined this board, can someone help me out...
what is a 60degreev6?
The 60* part is the angle of separation between the V's. The 6 is obviously the number of cylinders.
Engines include:
2.8 V6 (2bbl FWD, FI FWD & RWD)
3.1 V6 (FI FWD & RWD)
3.4 V6 (FI RWD & FWD)
3.4 V6 DOHC (FWD)
3100 V6
3400 V6
3500 V6
And, I think there are a couple of newer ones in there that I don't know about.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Your Cutlass will be a 3.1, not a 2.8. The 2.8 went away early on with the Cutlass. I think 1990 was the last year for it, not positive, though. Either way, you've got good cars there, probably. Have fun!\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Of course this site is ONLY deticaded to the Chevy V6.
Most V6's today are 60* V6's because that is the best angle to make a V6 engine at.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Then it's not a '93, or someone for some reason swapped a 2.8 in place of the original 3.1, or the last possibility, someone swapped the plenums.Originally posted by dragon29108my oldy has a 2.8l in it, i done sawed it with my own 8 eyes :0)
The last year for the 2.8 anywhere in the GM lineup was 1989, by 1990 all the (GM) car lines had switched over to the 3.1.
Re: RE: what is a 60degreev6?
Wow, 2 minutes late!Originally posted by firechikenOn this board, the GM 2.8, 3.1, 3.4, 3.4dohc, 3100, 3400, 3500, 3.6dohc, and 2.8dohc engines (check out the family tree link to the left). The 60 degrees refers to the angle that the cylinder banks are at in relationship to each other.
The ford 5.0L if you favorite engine? Ouch
My fav is probabally the Buick or Caddilac big blocks.
If you want to narrow it down to the engines today the I think I would go with the New supercharged N*1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Some of them do, yes. A lot of the same upgrades, more importantly, should also apply. You just end up with a smaller bore by 3mm, if I remember right.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
