*brian89gp*
Split off from here: http://www.60degreev6.com/forum/viewtopic.php?t=1155
*brian89gp*
What you should do is send your turbo off to Performance TEchniques in California. They will give your exh wheel a 10 or 15 degree clip.
This in effect will allow more exh gas to flow by the turbine before it starts to spool, so it will spool slower but will also give mroe top end power as there is less of a restriction.
I wish I knew you were putting this turbo on your car as I would have told you from the start that it was too small.
It was designed for a 3.0 liter motor and you slapped it on a 3.4. Even from Toyota for the 3.0 its a bit on the small side as far as exhaust goes cause these guys get there exh wheels clipped all the time.
What I would do is send your turbo to PT, have them install a 60-1 compresor wheel, and give it a 15 degree clip. total Cost? $450. Increased power? Well pends on how much boost you run but that compressor wheel will push a bunch of air at low boost. SO you can run the same boost as you do now but make more power.
Thats my point of view I guess.
Iwouldnt' ditch that turbo, just doa little upgrade to it. YOu wont' be dissapointed. If not then I might buy it from you.
shaun
*brian89gp*
shaun
