i was just curious what would be the vices or virtues from a twin turbo setup off of a wrecked stealth or 3000gt or can it even be done? as far as timing and all that goes could some kind of professional could maybe use the info off of the stealth chip or 3000 chip as a guide? i believe these engines were 3.0l dohc v-6's?. im pretty sure compression would be an issue. but could you just limit the boost and or change timing? i believe the 3.4 has a precise enough fuel delivery system. and if you would go turbo a custom chip would definately be called for. im sure you guys have had this discussion be4 i just wasn't here to catch it.
dohc twin turbo ???
