The new 3.6L DOHC motor is the only 60 degree engine I'm aware of that has a forged rotating assembly including pistons. The closest you can get to using them is in the 3500 block which has a 94mm bore and 84mm stroke, the 3.6L has a 94mm bore and an 85.6mm stroke which depending on the pin placement in the piston might work out perfect if it brings the piston down 1.6mm because the 3.6L has a 10.2:1 compression ratio which suggests you would still have good compression for forced induction. The forged piston information is from GM not speculation or hear say. Even the main bearing caps are steel.
On a different note, until you see it documented there is no telling what type of material GM has used to manufacture various parts especially in the new 34-35 and 3900 the latter two offered with a steel crank and higher compression ratio suggesting a piston upgrade is warranted over straight cast given the added stress. Who knows. Regardless, todays cast piston is certainly a better part than those produced years ago.
Per GM Parts direct:
2006 Cadi CTS 3.6L piston= $50.60, rod $50.22
2006 Malibu Maxx 3500 piston w/pin only= $75.30 rods $42.12 and $29.86
2006 Pontiac G6 3500= $75.30 includes connecting rod
I would say it's worth investigating, I imagine the rod price difference for the malibu involves 3" and 3.31" differences for that year engine. 1.6mm is not a lot and it is very possible the 3.6L piston has the same pin location as that found on the 3500 piston and that's what resulted in a jump from 9.8:1 compression in the 3500 to 10.2:1 in the 3.6L. We just need to know the rod specifications to verify it. The forging process probably accounts for the price difference between the two.
The CTS pistons are forged aluminum and full floating in piston and rod.
love my 3400
