3500 plenum and wet nitrous
  • #31
    oops, posted the same thing twice.
    • #32
      You can make it work, but if it was fitted for a 3100 then yeah it will change it slightly. I'm still runing the stock air box and air tube on the 3500 plenum and it fits, but the air tube to the box is a bit more squished.
      [/SIZE]
      • #33
        Update- Im running a dry shot right now and having absolutely no problems. Tuning was a breeze. I pulled out 4* timing using the table for IAT vs. timing for my first couple of runs. It didnt knock at all, and it wasnt running lean. Ive been able to put 2* timing back in with no troubles at all.
        I just wish I could figure out my misfire problem now so I can spray at the track damnit
        • #34
          i've seen them do it with mustangs, you can use the vaccum block and run the juice into a vaccum port on youre intake
