well i've been doing some more research and found that the 2000+ 3400 stock injectors will flood the engine with the 95 beretta 3100 ecu correct?
well what if i was to add a rear mounted turbo to compensate and add more air? i have a t25 that i can use and piping and intercooler shouldnt be too tough. dont plan on high boost just enough to make the newer mulitec 2 injectors work with this 95 3100 ecu that way the engine puts out the power its supposed to maybe a little more. since im starting to think this 3400 swap isnt going to please me power wise.
