Finally got thr rsm charger fixed that i bought from black00gt1, thats for another day. the problen i have now, when i put the vacuum hose on the blowoff, it starts missing and idling bad, i raised the idle still the same. with the hose off and pluged the idle is normal, played with the blowoff adjustment no different, i'm thinking a bad valve, i'm open to ideas.
blowoff
only if the BOV is after the maf do you need to recirculate it to the intake.. If the BOV is before the maf you can vent to atmosphere because the air is not being metered by the MAF.. you wanna keep it about 8-12" before the maf from what i have always been told.Originally posted by evilmiata View PostThat's what I thought. MAFs aren't compatible with BOVs that vent to atmosphere. Reroute your BOV back to the intake or get a stand alone ECU that uses a MAP sensor.Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
yeah, its common on boosted GM's.Originally posted by evilmiata View PostI'm sorry, guys. I didn't realize that the BOV was in front of the MAF. I don't think I've ever seen firsthand a MAF on the pressurized side. Nice.
SShane "RedZMonte"
i had the same problem with a 07 cobalt i turbod last winter , that same prob and when under full load the maf frequency was going crazy. talked to a few guys and found putting the maf on the charger inlet fixed it . no spurratic readings and smoothe idle. idk if this will help you much but it deff helped me
