I've been researching a turbo application for my car on and off for quite some time now and I was wondering if you guys could clear up a few things I can't find answers to after reading and searching countless threads. I understand that the smaller the ar on the exhaust side the faster the turbo will spool and start making boost (read that one) but it will have lower torque to spin the blower side of the turbo (implied but not directly stated in a thread). Is that correct?? So a t3/t4 t04e with a .63 exhaust and .50 blower will spool quick but wont make much boost?? What does AR stand for (air ratio) and what does the pitch of the wheel do in relationship to the AR?
If I was to pick a turbo right now it would be a t3/t4 to4e but I have a feeling it's to small. or a T4 t04b but it may spool to slowly. If that's right about these two is there a happy medium?? Im looking to keep my car as a weekend toy not a track car so making 400 hp isn't the goal more like 280-320. I would like to get it up to 7-10 psi. any suggestions?? Most likely I would have to use a FMU and get some ALDL gear from moates... I've seen RRFPR around is that the same as a FMU but with a gauge??
