This what I have:
87 GMC S15
3.4l GM performance engine
700r 4 trans
Holley 502-3 Tbi
Custom ecu
Istalling t3/t4 turbo
I'm going to install the turbo in the place of catilitic converter. Coping what STS is doing with thief systems. I have a few questions I know about getting pressure to the turbo, but short of cutting a hole in oil pan is there any other methods of getting oil out of the turbo? I thought about a sandwich adapter but I think that would run too much oil though the turbo. What kind of pressure are you guys running ( real numbers please). I was thinking of starting with 5 psi to start. With the tbi I have. I figure much more and I will have to start adding fuel nozzles. I. M running a internal waste gate with a mannuel ajduster where do I tap into? I' m also have a pop of valve same deal? Boost gauge take off at intake?
I'm building this system from scratch. Something different than growing a V8 at it. Anything you can throw my way would be helpful
Mike
87 GMC S15
700r 4 trans
Holley 502-3 Tbi
Custom ecu
Mike
