Just bought the car with a bad trans. Replaced it with a junkyard 4t60. (I know the trans is only gonna last about a week with that motor... I know) When reassembling, everything went great!
I had a clamp that was loose by the starter, so I went to tighten it and shorted off the starter. After replacing a blown fuse I took it for a spin and got no boost, maybe 2lbs:
I have since then replaced the oil sending unit, plugs, wires, double checked all the vacuum lines (except under the uim), and charge pipes.
Im still getting no boost. The car runs like junk too. In the first video she purred like a kitten. Now it shakes and when your barely on the throttle you can feel the power coming in and out.
Ive been on TGPforums
HELP ME!!
HELP ME!!
