just got my newest issue of CC, going through it, saw the regular stuff, then i got near the back, page 86 if anyone else has it, and i saw this.
"since the action didn't count toward the season's points total, william modified his '93 grand am with more than the class rules would allow by dropping a supercharger on top of his 3100 V6. knowing a thing or two about these engines, we stopped for a closer look. these never came supercharged from the factory. william told us he took the blower from a 3.8L bonneville, cut a hole in the top of an extra manifold he had, and put the two together with a thick layer of RTV silicone in between. "i had to let this sit for four days to cure. when i tried it before, i only let it sit for two days and the pressure in the manifold blew the silicone out. this one works great so far though.""
according to the caption above it, he's pushing 9psi...
sorry for the bad pic, but my scanner hasn't worked in quite some time... it is without a doubt a large port manifold.
i can't believe silicone will hold the 9psi.
NO_DOZ, i found you a cheap solution...
i'm also stoked that CC finally has a 60* motor in it, maybe there will be more to come?
