Ok. For my turbo I plan on tapping off the oil pressure sensor. Anyone know what size fitting that I would need for a tee fitting?
Then for the return, is there an oil gallery that I can just remove the plug from and tap in there? I was planning on just tapping the oil pan, but I wanted to see if there was a gallery in the block i could tap into.
