well rite now im working on a 3.1L v6 and im going to procharge it by eliminating the A/C compressor and putting a procharger c1 or c2 rite where the compressor was...so i wana know if anyone has tips or thoughts ideas etc or anything i should no about please let me know
procharged 3.1L v6
Will be expensive and probably very difficult to have a straight riding belt that will not wear fast, slip, &/or pop off. I'd recommend a cam since you will need to produce initial power to make more power.Lifting my front wheels, one jack at a time.
He should have a 7730. That will be an easy part of the equation as long as he finds a reputable tuner and not some shmoe that wants to throw more parts at it (secondary injectors, using of a MAF with SD, using an piggback for ignition timing/edis module and hacking in resistors) when not truly needed.
Proper belt routing and tension will be difficult with his transverse situation. He doesn't have a RWD 3.4 setup like you.Lifting my front wheels, one jack at a time.
there seems to be no shortage of those lately...Originally posted by 1988GTU View PostHe should have a 7730. That will be an easy part of the equation as long as he finds a reputable tuner and not some shmoe that wants to throw more parts at it (secondary injectors, using of a MAF with SD, using an piggback for ignition timing/edis module and hacking in resistors) when not truly needed.
"HURR YOU INJECTAS IS 2 BIG, CAN'T GET DEM UNDA 8MS!"
but yes, guessing by the screen name, beretta GTUs with a LH0 would have a 7730, you could just run TGP code and be almost done with that alone. code 59 could work better but would be a bit more involved.
dem der motors needs carbs son!Originally posted by robertisaar View Postthere seems to be no shortage of those lately...
but yes, guessing by the screen name, beretta GTUs with a LH0 would have a 7730, you could just run TGP code and be almost done with that alone. code 59 could work better but would be a bit more involved.Lifting my front wheels, one jack at a time.
