I have finally decided to go with boost on my engine build rather then NA/hybrid. I was hoping to get some help from other more experienced members.
My plan is to build a mildly boosted, low cost 3400, mostly stock, with a max of 275-300whp. My 3400 is in my 86 Fiero running off a tuned 7730 ecm.
I am hoping people can help me select the right turbo for the application. I am thinking the to4e but I'm not sure.
Stock 3400 bottom end
Stock heads (should I do valve springs?)
65mm LX5 Tb
Intercooled
3100 rear manifold and custom crossover (wastegate attached to old downpipe flange like the 3800 cartunning kit)
2 bar map sensor form tgp
I was thinking of using the tgp chip to get it running and tune off of it, unless someone is willing to share a better tune.
65mm LX5 Tb
Intercooled
