Turning the false KR into a spark retard for spool. Pull decay back and reduce the spark pulled vs rpm.
I finally figured it out, though I suspected this for some time.
The turbo spooling up will trigger false KR. Being the KR module looks for a specific frequency (sound) the turbo will hit that frequency as it spools up and then pass it by.
This is what I found, the turbo will not trigger false KR unless it is spooling up. No false KR once fully spooled so I can keep the standard settings past 3600 RPM. For a turbo, thats cool.
Now comes the cool stuff. False KR is bad, obviously for lack of power, though retarding spark while spooling is somewhat beneficial. As long as the spark isn't retarded too much.
Now, I kept regular KR values above 4000 RPM, since the turbo is hardly ever spooling above that RPM. So I have knock protection when it counts, in boost.
What I did was reduced the amount of spark the KR system can pull between 2800-3600 RPM. Just enough to let it act as an anti-lag system.
Anyone suffering false KR with a turbo, this might be the issue.
I turned a problem into a benefit. Using the false KR from spool as anti-lag. And it works, as far as the logs show. MAF delta rate of change is slightly higher with the anti-lag concept on, immediately after the false KR.
