I've got a 3.4 out of a 94 Camaro that I'm swapping into a 72 MGB-GT. I plan on building a twin turbo setup, my question is, What internal weak links need to be addressed for this engine to handle 12-15lbs of boost? The last DIY turbo I did was in a 90 miata. That engine was derived from a factory turbo motor so it already had beefy rods and oil squirters on the piston undersides. The internals were good to go.
So, where is (are) the weak link(s) in the 2.8 - 3.4 family of pushrod engines? (Assume I'll take care of proper intercooling, engine cooling, ignition timing and fuelling for boost)
Pistons?
Rods?
Crank?
Valve Train?
Oil pump?
Studs?
Heads?
I know the ignition system is strong enough and easily upgradable with higher output coils. Thanks in advance for sharing your collective wisdom.
Brian C.
Pistons?
Rods?
Crank?
Valve Train?
Oil pump?
Studs?
Heads?
Brian C.
That's just a measuerment of silicon content in the aluminium. Eutectic being IIRC 15 PPM, Hyper being more than that, Hypo being less.
1980 MGB Roadster - V6 engine swap commencing....
