Originally posted by leong6gtp
View Post
HUGE part out
The swap from a 45e to a 65e requires custom axles (65e hd axles are not plug and play), it also requires custom mounts and a PCM recal.2000 Grand Am GT
2011 Chevy Impala
what i am saying is i have a 65e transmission already, the fact that the differential on the HD version is bigger and has shorter axels which my guess is to accomendate the bigger diff. since the standard 65e was in the GP already on the non-SC version and its the same platform of course they would make it so when they introduced the HD trans into that car that it would require minimal modification. so when upgrading to the 65eHD will having the axels make it a pretty much direct swap is what im asking.Originally posted by onefastV6 View PostThe swap from a 45e to a 65e requires custom axles (65e hd axles are not plug and play), it also requires custom mounts and a PCM recal.
Yes. Only one of the axles is different, I believe the drivers side, and the other can be re-used.Originally posted by leong6gtp View Postwhat i am saying is i have a 65e transmission already, the fact that the differential on the HD version is bigger and has shorter axels which my guess is to accomendate the bigger diff. since the standard 65e was in the GP already on the non-SC version and its the same platform of course they would make it so when they introduced the HD trans into that car that it would require minimal modification. so when upgrading to the 65eHD will having the axels make it a pretty much direct swap is what im asking.2006 AWD TBSS 12.538 @ 106.92 1.66 60' Bolt-ons only
pending your answer and one from my machinist....
Those rods still available?
oops, not enough coffee, didn't notice you posted that right last!
can you shoot me a pic of it?sigpicHow to make High performance Emissions:
