I need a new/used throwout bearing for a 284. I don't really want to buy a whole new clutch kit as that is already newer...The bearing listed on Rockauto is not the correct part, and I've dropped off the old one at a few parts stores but they can't match it up. The "tabs" that the clutch fork slide into are broken on one side, so I can't engage the bearing into the retainer on the pressure plate during re-assembly. Let me know what ya got!
284 throwout bearing
can you post a pic?
it might be the same bearing that the 282 uses...
ok, yah.. that's different than the 282 one.
good luck!
I posted on w-body that I have a good one still on the pressure plate you can have (pressure plate included) for $75Last edited by bigalwalker08; 10-30-2009, 02:05 PM.Alex (Big Al) Walker
someday GM will pull its collective heads out of their collective asses and listen to us... or go bankru... oops.
