Having a small part out. Changing directions with the car. Most parts are used except fot the valve springs, bearings and couplers. I'm open to offers and trades so prices are negotiable. Let me know what you've got. Pics available upon request.
Cavalier
95-99 cavalier 2.2 intake w/ AIT sensor -filter $20
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $30
95-05 cavalier 4t40e trans mount $20
95-99 cavalier 3 speed trans mount $20
95-99 cavalier 2.2 ohv front motor mount $10
95-99 cavalier 2.2 ohv alternator $20
02-05 cavalier 2.2 ecotec throttle body -tps $20
95-02 cavalier radiator cover $5
95-99 cavalier gauge cluster w/o tach $15
95-99 cavalier 3 speed shifter assembly $15
Grand Am
4t45e side cover $20
3400
3400 exhaust manifolds w/ crossover $30
3400 coils w/ icm and ac delco plug wires $40
3400 throttle body -no sensors $20
3400 alternator $30
3400 p/s pump$20
3400 gear reduction starter $30
3400 egr valve $10
.10 over crank bearings $40
WOT-TECH 3400 Ishihara-Johnson crank scraper $50
3400 windage tray $15
3400 pistons and connecting rods w/ new standard bearings $70
3400 p&p cylinder heads w/ port matching (still at machine shop) stock valves and springs $150
3400 lower intake $30
3400 block -hot tanked,honed, glyptal coated and machined oil passages, new cam bearings (prefer local pickup) $120
3500
3500 upper intake $90
Comp Cams 26915 springs -new $110
36# GTP injectors w/ pigtails $100
Misc.
Holset hx30w turbo for parts only -broken shaft $40
2 used 4 wire 02 sensors $10 each
20 3" diameter x 6" length silicone couplers $5 each
Cavalier
Grand Am
3400
3400 alternator $30
3400 p/s pump$20
3400 egr valve $10
3500
Misc.
