i need a wheatherstip for my driver side window on my 96 monte, cant find one. any1 have one or know where i can get one?? thanks
cant find a wheatherstrip
Which "weatherstrip" exactly do you need? Are you talking about the channel felt, or the outside dew wipe (that's the part on the top edge of the door that wipes on the glass)? If you can look at a factory parts image and identify the part you need, then get the most current GM part number it will help greatly in your search.
Hmmmmm, I kinda doubt that. The left door is the one that gets opened and slammed the most which is quite abusive of the nylon and abs retaining clips. The one on my ZX2 is hanging on by a thread at the moment. That piece is also commonly called the "dew wipe" or "outer window weatherstrip" . It should still be available from your local GM dealer or online seller of GMSPO parts. W body cars are still in wide use and many of their parts are interchangeable between makes.
I also see them by the metric butt-load in the junk yards. I had to get that same piece for my truck, paid ~$5-10 IIRC.-60v6's 2nd Jon M.
