Everything sold, thanks everyone!
3500 LX9 Performance + Swap Parts
Sure thing, I'll take some more this afternoon when I get home and put them up.
It has been sitting in the same box that I received it in from WOT 3 years ago, so it should be basically pristine.
I'll get all angles and such later on tonight.Last edited by bungee91; 09-20-2012, 01:50 PM.
Is the UIM bell mouthed or just gasket matched? I can't really tell in the pictures. Also, is the external crank trigger the adjustable style or not?You may or may not know 10 times what i do.
I'm honestly not sure at this point and will need to get this verified from WOT.Originally posted by Z26-T View PostIs the UIM bell mouthed or just gasket matched? I can't really tell in the pictures. Also, is the external crank trigger the adjustable style or not?
The external crank trigger is the adjustable style.Last edited by bungee91; 09-30-2012, 09:05 PM.
Porting info requested about the "stage" on the UIM and LIM, sorry for not knowing this originally. I do have someone interested in both as of right now.
(sorry for directly quoting you Ben...=P)
"The comp 3500 set would be level 4 upper and lower. Hope that helps
Sportsman was the gasket match and blend a couple inches in.
Ben Phelps
WOT-Tech"
how are PAC valve springs a upgrade on the lifters, im lil confused as their is upgraded springs for lifter that comes from ls lifters94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
