casually looking for another one in the event that I bork mine with experimental code patches, I also need one to tear apart for study/comparison, so the 4 main T25 torx screws MUST be removable, the knock filter cover isn't critical. mine are all very seized in the housing, otherwise I would take advantage of this downtime and crack this one open.
ideally, I'd like to get ahold of a 94-95 3.4/auto(16184737) unit since they do appear to have some extra hardware in them compared to the 3100 and 3.4/manual(16194737) PCM, but it wouldn't bother me that much to have just an exact spare of the one I have now.
so, should somebody happen to be at a yard that is having an "all you can haul" event or something like that, the <5 minutes to pull one from an underhood application(W and F-bodies) would be worth a few dollars per minute of work to me. an ~8" flatblade screwdriver with a ~1/4" or somewhat wider tip makes it a cake job to remove the otherwise stubborn connectors from the PCM and the PCM from its tray.
