WTB 3.4 DOHC Cams. 1997 or close to that year. I really only need the rear exhaust cam. But most people don't want to break the set. Which I understand.
WTB 3.4 DOHC Cams
WTB 3.4 DOHC Cams
1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
Tags: None
hey, your best bet then is to call a junkyard. they charge about 50 bux a cam. also 97 will may be the only year i think u can interchange with. unless u get a set of older cams and bolt them on but unless u get a 96 set, u will have to get the drive gear as well. a guy on pff said the lobes are different on those cams b/c of the smaller lifters(like thinner or something like that).
i can check the junkyard next time i go there. i can probably get u a set of banks for about 85 but shipping will be high.The Official Rotating Mass Nazi
Ya that was my post about them being narrower. (at least on mymonte.com) But they will work. There's about 0.010 difference in width. I was hoping to get something a little closer then you. But thanks for offering. If none turn up. I'll still take you up on the cams and carriers we talked about.Originally posted by dohcfiendhey, your best bet then is to call a junkyard. they charge about 50 bux a cam. also 97 will may be the only year i think u can interchange with. unless u get a set of older cams and bolt them on but unless u get a 96 set, u will have to get the drive gear as well. a guy on pff said the lobes are different on those cams b/c of the smaller lifters(like thinner or something like that).
i can check the junkyard next time i go there. i can probably get u a set of banks for about 85 but shipping will be high..1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
