I have quite a cache of 3100 and 3.4 parts im not going to use. Im going to keep the sensors and things around, but the big stuff MUST GO!
3.4 Crank (80K miles) Looks good, woudnt be a bad idea to get it reground but may not need it at all.
3.4 Upper intake (one bolt is broken off in the EGR Flange, just needs to be drilled and tapped. FREE with any other purchase.
3.4 Valve stems seats (or seals? they're the small cylindrical brown thingy's) whole set, brand new, still in bag. Felpros.
3.4 Heads. Just need a thorough cleaning. They have not been measured. 130K miles.
3.4 Cam carriers and a set of lifters. they need COGS. just clean and go, or rebuild if wanted. Comes with a set of new cam carrier gaskets if needed.
3.4 Timing chain and gears (crank + I/S), 80K miles. they look good but not sure if its a good idea to reuse old stuff or not.
3.4 Fuel rail and Fuel injectors (they are from a 94-95 engine, return and pressure line have the screw-in type connectors) 80K miles
3.4 Valve covers.
3.4 crank case cover
3.4 Oil Pan
3.4 Oil Pump
3.4 Power Steering pump
3.4 Air Compressor, still works, designed for 94-95 (80 K miles)
There's more 3.4 stuff than this, lots of little things like bolts and such and other hard to find goodies. if you think i have it just ask.
96 3100 Stock Throttle body
96 3100 MAF sensor
96 3100 PCM + Tray (Grand Prix)
96 3100 Alternator 7000 miles on it. CarQuest brand.
Make offers, most of the cost will be shipping in a lot of these cases, some of the bigger items i would prefer pick up.
3.4 Valve covers.
3.4 Oil Pan
3.4 Oil Pump
96 3100 MAF sensor
