I have LTFT numbers in the area of -17, while STFT is usually sitting around -08 to 0...but never above, never adding even a little to the mixture... FPR works, actual pump pressure is 36 (down a bit), and my fuel system is clean... also no vac leaks...
im not sure what to make of the evap, could possibly be the source of the rich mixture...assuming the solenoid is opening when it shouldnt.. at operating temp at idle, evap is a 14%... seems at least practical, low idle, low vapor draw?? any ideas welcome.
Another thing to note... pulling the vac off the FPR raises the FP the normal amount.. FPR doesn't leak into manifold... LTFT numbers will rise and stay at -4 with the extra air let in by the FPR vac line... just a note if that helps.
1997 3100 SFI
*new upstream 02
*new LIM
*fuel pressure holds with engine off
*any fuel managment sensors are at least operating within tolerable range, but i dont know the exact values they SHOULD be at... any references to the info greatly appreciated.
main point is that Long Term Fuel Trim numbers are normal kept as close to zero as possible.
(motor&PCM stock)
1997 3100 SFI
*new upstream 02
*new LIM
(motor&PCM stock)
 I'd like to double check the sensor values... but I'm thinking something must be up with that cat...
