I've only spent a few days reading and searching on this, you fellows seem to have your stuff together, so I thought I'd run it by you.
I'm planning on retrofitting a 2 barrel TBI setup to a 2.8L DOHC inline 6cyl Mercedes engine, 6500rpm redline, makes 150hp or so stock in low compression USA trim.
I'm not looking for power really, but I don't want it choked if I can help it.
This is a 73, so it's old school with no cat or other emissions equipment, auto trans.
It has a points distributor that I plan on using a petronix breakerless conversion kit with an MSD ignition box, which I'm told will supply TBI with an ignition signal it'll be happy with.
Couple questions.
The GM 2.8 TBI don't make a lot of power, but I figured it'd run OK with the stock maps till I get it settled out, being the displacement is the same. I wonder though, if even with some chip tuning if it's going to be restrictive on a motor turning so much RPM and making as much power as it does compared to the stock application? I could use the 4.3L T-Body, but it'd be rich at lower speeds I imagine. Thoughts?
Also, I can track down what years and models had what motor and TBI, but are there preferable years to look for? The VSS is going to be a bit of a pain in this swap, but do-able. Are the older one's going to expect a VSS signal too? If I could find a breakdown of ECM model numbers stating what they were from and the differences that would be great. I need somewhere to start hunting for parts basically.
Lastly, I have thought about MegaSquirt with a throttle body for this application, part of the attraction though is that this should, I hope, be a fairly bolt on and run setup. I don't really want to spend the time honestly tuning MS on this thing, it's not a very common application to say the least. Am I going to end up with more effort in GM TBI than with MS do you think?
Thanks so much for you time and any thoughts you have.
Couple questions.
