I'm back at the 3900 swap and have code59 wired up and apparently ready to run. I noticed on datalog link up that my TPS voltage is at 100% and 4 volts with the throttle closed and declines to about 2.3volts as it is opened. I checked the terminals against the wiring diagram and they are correct. This is on the Northstar throttlebody which worked properly with the 8F code the engine was previously wired for.
The IAC count is 138 and red, not sure how to interpret the counts yet. I did try to start the engine and it ran for about 3 seconds twice but that was before I tried to datalog earlier in the day. The heated O2 sensor is also reading 8.8 mV, not sure how it will change once the engine is started with the emulator connected.
