Cranks over and runs for about 2 seconds then dies out as accelerator is pressed and rpm starts to climb ending with backfiring.
TPS sensor is reading properly
MAP Functioning
MAT sensor working
Timing advancing as expected
Fuel changing and spark adjustment isn't making to much of a difference at the moment.
I believe I'm the only person using Code59 with DIS so their maybe a problem that hasn't been worked out although it is setup for DIS in this application.
I'm going to check the base timing. I have the cam fully advanced now and noted good vacuum coming up on the gauge during starting compared to what it used to be but I'm at a loss for why it keeps backfiring and will not run continuously.
MAP Functioning
MAT sensor working
