The 7727 and 7730 are suppose to be the same except for the case. The 7727 ECM uses C21 to measure the 0~5v A/C pressure signal and I was wondering if the 7730 has the same ability. If so, what pin is used?
7727/7730 pinout question
MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
http://www.britishcarconversions.com/lx9-conversionTags: None
I think it's more how the bin uses the inputs..
F14 is the input with $A1 on a 1227730 that is normally for the pressure switch, however with the wideband hack that's the input we use to log the 0-5V data.
Thank you gentlemen.... exactly what I was looking for.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
