$3F files
  • $3F files
    ive downloaded tunerpro rt, picked up a chip burner and some proms, made an aldl cable and am ready to start tweaking my s10. problem is, i only havethe stock $3F .bin filw, and canot find the .ads or .xdf files anywhere. i tried moates, diy-efi, mxscan forum, thirdgen.org, etc and have had no luck. does anyone have these?
    if i need to, ill just swap ECM's to a 92 ECM that i have from the parts truck (also a 2.8 5 speed s10), but then i would need to find all the files for that ECM.
    anyone have anywhere else for me to look, or hav the files they could gove me? i really wanna get this thing dialed in with the bigger TB, headers, Exhaust, 1.6 rockers, and deleted smog.
    thanks
    Michael
    here is the $3F .xdf.. i'll look around for the .ads
      thanks,man.
      michel
        probably wouldn't take too long to make the ADS if Dave can't find it... i did one for a member on here for a 4E ECU, only took a few minutes...
          and i have no idea how to go about doing that. is there a how to or something i can follow?
          im new to the efi stuff. whole reason im doing this is so i can learn new skills.
          michael
            its kinda confusing, but once you get into it, its not bad...
            thats what you need to make the datastream definitions...
            EDIT: as far as a how-to...... i don't know if anybody has ever made one.
            you know what, browse through the files in there and see how confused you get, in the meantime, i'll make a 3F definition for you.
              actally. i found the ads on the moates site. amazing what a nap will do for your eyesight.
              michael
                that works too...
                  you said you had a ads for the 4e? is there any way i can get a copy?
                  thanks
                  Micahel
                    i can send you the ADS or ADX for TP, just send me your email address through a PM.
