$8D - Anyone Else Using It?
  • $8D - Anyone Else Using It?
    Just for fun this afternoon I tried the s_aujp v4 $8D code to see if it would run my hybrid 3.1. It did start and idled fairly good considering nothing had been done to it besides setting the injector constant, # cylinders, cylinder volume and DIS settings. I think I'm going to play with it for a while. Lots of neat features have been added to this version. Has anyone else gone this route? Just curious.
    -- Scott
    i made one for the GP at one time, but i like being able to take advantage of the EGR, so i went back to A1.
    [CENTER][B]1995 Monte Carlo LS[/B] 3100, 4T60E...for now, future plans include [B]driving it until the wheels fall off![/B][IMG]http://i598.photobucket.com/albums/tt68/robertisaar/NewSig.png[/IMG]
    Latest nAst1 files [URL="http://60degreev6.com/forum/showthread.php/48100-nAst1-Progress-and-Concepts-Thread?p=461016&viewfull=1#post461016"]here[/URL]![/CENTER]
    [CENTER]Need a wiring diagram for any GM car or truck from 82-06(and 07-08 cars)? [URL="http://60degreev6.com/forum/private.php?do=newpm&u=9626"]PM me![/URL][/CENTER]
      I started to play around with it but $A1 is working well for me so i stayed with it for now...
      [url=http://www.v6z24.com/registry/SuperDave]1991 Z24, 3500/5 Spd. 275WHP/259WTQ 13.07@108 MPH[/url]
      [url=http://www.v6z24.com/registry/superdave/5]1989 Camaro RS, ITB-3500/700R4. 263WHP/263WTQ 13.52@99.2 MPH[/url]
      [url=http://www.v6z24.com/registry/superdave/6]1972 Nova 12.73@105.7 MPH[/url]
        You soulless bastards...
        Scrap that crap and get with the times! lol!
        I'm not bashing, but when you can stare at a green blob moving around a VE map you almost drive into shit.
        '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
        1/8 mile 9.72@75 mph, 2.0 60 foot:owneddance:
        [url=http://videos.streetfire.net/video/fbf6af9e-55a9-4604-b3e9-9a290119f6c9.htm][img]http://thumbs.streetfire.net/fbf6af9e-55a9-4604-b3e9-9a290119f6c9.jpg[/img][/url][url=http://videos.streetfire.net/video/fbf6af9e-55a9-4604-b3e9-9a290119f6c9.htm] [/url]
          that's the point of recording the data and going over it later... and 30 seconds after that, i have a new VE table...
          and what green blob are you talking about? yeah, that's megasquirt, not GM ECUs...
            I've got $A1 in a rough tune now but I'm in the process of wiring in a Wide Band sensor and figure I'd want to start over anyway. There are lots of nice features in $8D I want to play around with too.
            -- Scott
              the expanded VE tables are nice, but for most people, completely useless...
                when i told the guys over at thirdgen.org about my build, they told me to use $8d and not $a1
                [IMG]http://www.johnlonganecker.com/teamg.jpg[/IMG]
                93 Firebird 3.4
                [FONT="Arial Black"][/FONT][SIZE="3"]Cam and Heads by [URL="60Inclusive.com"]60Inclusive.com[/URL][/SIZE]
                  depending on your goals, either could work. but there were never any 6 cylinder BINs running 8D released from GM, so it makes A1 that much easier/foolproof to set up.
                    they said it was more of a "performance tune" but that didn't make sense to me because i'll be modifying the .bin anyways for my own application and i just want it to run right more than anything.
                    93 Firebird 3.4
                      depends on who told you that.... RBob: i would trust damn near anything he says just due to his understanding of how everything works.
                      BUT
                      just because 8D was used on TPI 305 and 350 motors, doesn't make it a "performance" mask. i could run a quad 4 on 8D but it won't perform any better than on what it was intended for, could also run it on the various LT5 codemasks, and again, no benefit.
                      a lot of the algorithm between A1, 8D and DF is VERY similar, just modified to fit the application. example being that DF has some torque management built into it to stop the LQ1 from breaking FWD trannies. should you have a stronger transmission, you can dial all of it out and take advantage of all of the motor.
                        I’m not trying to sell $8D to anyone, don’t really care which way anyone else goes. I was just wondering what other people had to say about it. I’m intrigued with it after looking into it. Yes, the expanded VE tables are nice, much more resolution. Not sure how useful they will be in real life but they can't hurt. Some of the reasons I’m giving it a try are:
                        • Support for the NVSRAM module (changes on the fly)
                        • Built in support for several different WB O2 sensors
                        • Open loop idle option
                        • Started out in a performance application
                        • VERY well documented
                        • Lots of support when problems are encountered
                        As far using it in a v6 application, I can tell you that it took a lot of work to get $A1 to even idle when I first completed my hybrid swap. $8D started and idled the first time. It’s pig rich but it did start and idle.
                        Just my $.02.
                        -- Scott
                          I see in that thread it mentions boost, and from what I gather someone modified 8D much like people modified a bin to make code 59?? So this is modified 8D code we are talking about correct?
                          What is your setup exactly? Just because one bin idles better stock than another doesn't make one less desireable. It just means the one that idled better happened to have tables with VE stock that was closer to your modified motor. Tuned both would perform the same...
                          [URL="http://isaachayes.60degreev6.com/"][SIGPIC][/SIGPIC][/URL][SIZE=1][COLOR="RoyalBlue"][/COLOR][URL="http://isaachayes.60degreev6.com/z26/ss-todo.htm"][IMG]http://isaachayes.60degreev6.com/z26/signature1.jpg[/IMG][/url] [COLOR="#FF4000"]New 2010 project (click image)[/COLOR]
                          [/SIZE] [SIZE=1]16.0 1/4 mile when stock. Now ???[/SIZE] [SIZE=1][U]
                          Original L82 Longblock[/U] with LA1, LX9, LX5 parts
                          [/SIZE]
                            correct, but A1 is meant for DIS motors, while 8D is meant for a ECU controlled dizzy...
                            59 is also meant for a distributor, but can be modified to work with DIS.
                              yeah it was Rbob who told me that. but he said mainly it was because there is a lot more support for the $8d mask. But i've found plenty of support on this site for the $a1 and thats all that really matters to me
                              93 Firebird 3.4
