Entering Closed loop faster with $A1
  • tkoforpresident
    replied
    yeah thanks man, feels good to get the bird fixed up.
    Of course as soon as I get the bird fixed my explorer starts acting up... brakes are grinding.. not good
  • Schmieder
    replied
    Originally posted by tkoforpresident View Post
    Hey, so far so good. I installed the new chip, jumped the bird (battery was dead) and let it idle for a couple minutes. Then the moment of truth came and I popped it into drive and let it sit there for 5 minutes... Didn't stall out once. Reverse was fine too.
    I don't want to declare it after one single test but it looks like the problem *might* be fixed.
    How come we didn't change the map threshold sooner?
    Ben has some explaining to do
    Robert, thanks a million my friend. Let's hope we never get that code again.
    That's great. Good job, I'm bringing my engine back to life after sitting 8-9 months. Winter to Summer temps too, outside. Crazy NE weather, does a number with time.
  • Schmieder
    replied
    HORRIBLE idea... especially since A1 is entirely hacked, every single byte of calibration being adjustable as if we were GM calibration engineers themselves
    Ultimately, aside from the concept, I wouldn't do it to my engines PCM. I would find a much better solution. Resistors are more like road side quick last ditch effort to get home kinda thing, i guess. lol
  • tkoforpresident
    replied
  • tkoforpresident
    replied
    and i've got a spare map sensor in case it is the actual sensor being goofy.
    I'll burn this chip and then let you guys know the results.
    thanks
    replied
    well, since your cam doesn't generate a lot of vacuum at idle, we raised the threshold of where the ECM will start thinking there is a problem with the MAP sensor.
    this SHOULD prevent a MAP high DTC from being set during it's test period, at least it will as long as everything is working properly. if the MAP itself goes completely nuts(reading above the 91kPa when in a near idle condition), it should still set the code. much better than simply disabling it.
  • tkoforpresident
    replied
    got it.
    Robert you are so kick ass.
    Again though, what essentially have we just done and how will it help?
  • tkoforpresident
    replied
    ok... one more minute.
    replied
    and now i see why....
    press ctrl + F2 to bring up the XDF header editor. change Bin Size to 8000.
    then save XDF, close out of TP, reopen, change the value in the hex editor again, then save the BIN, should work this time.
  • tkoforpresident
    replied
    I just emailed the .xdf to you that i'm using
    replied
    sounds like problem... post/link to the XDF you're using(it may be mine, but i haven't seen it in a LONG time).
  • tkoforpresident
    replied
    ok i did it and saved the .bin
    just fyi there was an error when saving "one or more checksums could not be updated, check checksum addressing etc, for validity"
    should i be worried?
    if that's not a problem then I should be able to just burn a new chip and go datalog right?
    btw, what essentially did we just do? Disable the pcm setting off the map code reguardless of vacuum?
    replied
    the TP hex editor is how i impliment all of my patches, by the way....
    and i rarely have to go binary, hex works pretty well.
  • tkoforpresident
    replied
    ok hold on, this might take me a minute. I don't talk to computers in binary like you do
    replied
    addresses appear on the left, scroll down to where you see 4E0(may have a bunch of 0s in front of it), the click the value two to the right. at the bottom of the hex editor screen, you should see "Cursor: (bunch of 0s) 4E2", that confirms you're in the right spot, then just type DC
