Just want to double check;
I think this is normal,
At idle my Wideband is reading 21-22, Pcm O2 reading fairly lean as well.
I have been thinking this is just the PCMs way of reducing fuel consumption etc?
When I first started tuning and noticed I replaced the HO2s, no change, so I swapped out the Wideband for a new one and it was the same.
This is when I assumed it was normal.
Am I correct in this?
I guess I could change it in TinyTuners maybe, under
Fuel-Open/Closed Looped-O2 Sensor Rich/Lean Threshold
But is it necessary?
Mainly want to double check that this occurrence is normal?
