is osid 9352742 supported under DHP anyway? if so, mind giving this n00b the heads up on how? :P
dhp and osid 9352742 -
OSID list: https://spreadsheets.google.com/pub?...n1_K034oyJoMUQOriginally posted by hookdonspeed View Postis osid 9352742 supported under DHP anyway? if so, mind giving this n00b the heads up on how? :P
It isn't on the list, but I've had some supported that were not there. What is that OSID for? I've also had it where only the latest calibration was supported so you would either have to find the latest stock OSID and flash it with the DHP or have the dealer flash it if you can't find it on the internet. You can check the OSID level here:
Jesse M.
3x 1990 Turbo Grand Prix
1987 Monte Carlo SS Aerocoupe
If you don't mind send me the VIN by PM and I will see what I can find.
I am wondering if the file from a 98 olds silhouette would work http://60degreev6.com/forum/local_li...id=3&linkid=822000 Grand Am GT
2011 Chevy Impala
Quite possible, I currently use a 1997 Venture ECU and Bin file to run my 96 Beretta... Didn't have to touch or change one wire.
I use a 97 Lumina PCM to operate my 96 GP, and I too didn't need to change a single wire. But I did that for HPTuner compatibility. Seems like a quick fix for all 96'ers who want HPT tuning.Originally posted by 3400-95-Modified View PostQuite possible, I currently use a 1997 Venture ECU and Bin file to run my 96 Beretta... Didn't have to touch or change one wire.
If DHP can extract the file and burn the file, then Tiny Tuners can fix just about anything you need to change. I've set trans controllers to manual, 2-bar map, etc.
btw, I tried flashing a 98 file and it bricked my first 97 Lumina PCM. I don't think 97 and 98 firmware is compatible.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
96 was supported in DHP for me, but the 97 file had more tables mapped out and a larger file all together. If I want to go to HPT I would need a 97 Monte, or Lumina setup I guess.
TT is limited too, at least to the point of how many tables they have mapped. I know there are tons more that I want in my 97 file that he hasn't been able to add yet.
