Originally posted by unchained01
View Post
Eric, The VE table needs tuned just in case the MAF fails (if you choose to tune it). The VE Table max's out at 140 kPa, I set the 140 kPa tables to go extra rich. So if the MAF bombs out at peak boost (about 180 kPa at 12 psig) it won't go lean fueling for 140 kPa when it is really 180 kPa.
This is why the MAF sensor is so great. Not limited as much as VE tables are. A stock MAF should support up to 14.7 psi flow.
If you run real close to the limit, like 14 psi boost, you need good boost control. If you hit the limit the MAF or MAP can read, every step up in psi after goes lean.
But seriously, 12-14 psi on a fiero 3500 is going to slam doors and pull HARD.
