I finally had it with the limits of the stock PCM and not being able to get around the closed loop 14.7 AFR curse.  I do a lot of highway travel and had maxed out my tune with as much fuel as possible removed from PE and AE tables and ran my timing through the roof for better economy.
I had it built for about a year waiting to get my other project car done (no progress there) and couldn't stand looking at it any more. So I threw it in my Lumina with 3 10-way plugs (2 female, one male) to swap the injectors and ignition module wiring from the megasquirt harness to the stock PCM in case a tune goes horribly wrong or a hardware failure of the MS occurs. I hate walking.
I currently have the MS running injectors only, along with my wideband. As I get the tune sorted, I'll port over ignition control, and idle control, leaving the stock pcm to deal with the gauges and transmission.
My first impressions were of jumping into the deep end of a pool the first time. I was using a ton of fuel, it wouldn't idle, and I'd pull over and plug in the stock PCM to get to where I was going. After sorting out a few things and plugging the MS back in I am now beginning to realize there is a lot of potential here.
16:1-17:1 lean cruise, steady 12:7-13:1 under power, and I'm still working on my VE table. The engine also has a new smoothness and power to it.
I can't wait to get the tune finalized and move ignition control over to MS. Goodbye, MAF!
