I have the tuning nightmare 96 Grand Prix SE 3100 auto trans.
Is there a simple fuel/spark piggyback controller I can use for my custom turbo project instead of going 12:1 FMU?
Technical is ok, I have a good strong ability to make things work.
Just need advice on the perfect fuel/spark controller. Nothing fancy or special, just a basic fuel/spark tune for turbo.
Thanks!
EDIT: Something that works well with a wideband O2 would be nice since I have the WB already.
Are there any piggyback fuel injector pulse time reducers? If I had a Walbro high pressure pump and larger injectors, I would be injecting more fuel then factory had tuned for. It seems a simple dial in reduction of injector pulse width would do the trick. Advise? Suggestions?
Thanks!
