Wanting to build an effective and reliable boost controller. Oh and it's gotta be over the top! My goal is to use touch screen interfacing w/ the option of monitoring PWM, amps and position if servo actuated.
Other possibilities, adding SD card to data log, dynamic boost amounts per rpm/throttle, boost ramp adjustment for traction in 1st gear. Most of which would need an SD card to store the maps and other variables.
Also considering tapping the IAT to trigger an intercooler fan, boost reduction at high temps....and display IAT's
I know it is a LOT to do and will take some time, but we don't do this stuff because it is quick and easy!
Hardware (so far)
Arduino Uno
Seeed Relay Shield
Seeed Motor Shield
Arduino Kit (solder less breadboards, blank shield kits, leds, sensors, etc)
Lots of wire, capacitors, resistors, buttons, switches, fuses
Will get.....
touch screen
SD card shield
CAN bus shield (optional)
strong 12-16v servo (could use a voltage multiplier if needed to power more)
Solenoid for boost pressure to WG
* figured I could use both pressure and servo actuation to fine tune
I made sure to get a good 60w soldering iron.
I believe it would be wise to also build a separate simulation board to test the device before it goes on the car. Or at least have a failsafe in place.
This is literally the very beginning of the project. Lots of resources on the web, lets see where this goes.
The goal is over the top, revolutionary smart boost control.
Hardware (so far)
Arduino Uno
Seeed Relay Shield
Seeed Motor Shield
Will get.....
touch screen
SD card shield
