what is the easiest way to remove the engine from my car? 1997 malibu LS 3100sfi. have a bad motor and need to replace it.
first time, need help
Pull it out the top, seperate from the tranny.-Brad-
I always just used an extra jack stand to support the tranny while the engine was out.-Brad-
If you have the room and dont need to move the car, that will work to. I always have to wheel the car out while I work on the engine, so the trans has to be supported from above.Originally posted by bszopi View PostI always just used an extra jack stand to support the tranny while the engine was out.I modify stuff
