I'm about two days out from installing the engine and need to know coolant flow directions. The engine has a "U" flow pattern with inlet and outlet on the front of the engine, the thermostat is installed at what appears to be the pump housing inlet but it is facing in the opposite direction of traditional flow with the pintle end facing the inlet. Then there are the two lines that run along the valve cover to the throttlebody end.
You can see pictures of the hoses here,
The stat is behind the red plastic cap and it has an extended end that also covers a little hole in the back that apparently blocks coolant from going up to the top line.
