Okay, a little bit of progress.  I re did my grounds so now they are run to the factory location by the water inlet.  I am now able to run a wire from the ignition to the pink wire going into the two pin connection being pluged into the top of the icm.  the wire no longer gets hot or smokes.
Now when I turn the engine over it actually fires, but will not fully catch...it burbles for about a second then turns off. So I am still having problems. With the cam postion sensor I am still not getting 12Vs when the ignition is switched on to the pin that should be getting 12V I am guessing this may have something to do with my problem? With my set up is the ECM supposed to be feeding the cam sensor power or is that something that I need to be running from the ignition?
Also when I push the gas pedal it does not race the engine or anything, it still cranks/sputters out the same way it does if I am not pressing the gas at all. Any suggestions? I'm going to go look over wiring diagrams more.
